RCU Forums - View Single Post - Stick tension
Old 06-14-2006 | 08:02 AM
jlkonn's Avatar
jlkonn
Default Stick tension
Don't know if I've just never noticed or the plane I am setting up to start back in to pattern has that much better servos, linkages, hinging, etc. I haven't test flown it yet but setting it up on the bench I noticed I get some unwanted movement of the surface that is shared on the stick. That is when I move the ailerons I notice slight movement of the elevator and vice versa. Same when I move the throttle I see some rudder.
There's nothing wrong with the radio and I have conservative pattern throws with about 20% expo. I am slightly cross moving the sticks because I believe I may have the stick tension too light.
Does anyone have a theory or rule of thumb about this?
Thanks!
JLK
