RE: Bad Pushing Problem(w/ hyper PCR)
Run the least amount of caster possible, put your top shock mounting points on the inside for front and outside in rear (this should help atleast a little), more toe out in the front, less toe in on rear, more anti-squat in the rear is supost to give more steering but I never tried it myself, eveything else that you can do has already been said. If you still need more steering I guess clip off some tread from your rear tires [:@]. I had a hyper 7 PBS for my first buggy and I couldn't do anything to make it turn like I wanted it to.
