RCU Forums - View Single Post - Incidence
Thread: Incidence
Old 06-15-2006 | 08:19 AM
Campy's Avatar
Campy
Default RE: Incidence
ORIGINAL: SHARADEDGE540
Hi guys,
I want to know how to set correct incidence on my airplane which i build from kits having plans and having no plans. Kindly also let me know about setting correct incidence on ARFS.
If the plane is supposed to have incidence it is NORMALLY INDICATED ON THE PLANS.
For setting the incidence you will need an incidence meter. I use the Great Planes laser incidence meter.
How I set the plane up is:
For positive/negative incidence:
I block the plane up and use a small level on the horizontal stab to insure that this is level. Then I "zero out" the incidence guage on a level surface and clamp it to the main wing. At that point I adjust (shim ) the wing as needed to get the incidence I need.
For ARFS and other planes:
For ARFs and other planes with no incidence given, I assume it is a 0/0 incidence (0 incidence on the main wing and 0 incidence on the horizontal stab ). With these planes I zero out the incidence meter and clamp it to the main wing. Then I block the plane up until the incidence meter reads 0. Then using a small level, I make sure the horizontal stab is at 0 degrees.
The reason I do it differently for ARFs and other types of planes is that it is usually easier (less work ) to shim/adjust the horizontal stab than the main wing. I ALWAYS check the incidence on ARFs. While it is unusal, I have found a couple of ARFs that had positive/negative incidence, even though the manufacturer has stated that it should be a 0/0 incidence.
Hope this helps.
