Barry..... Maybe you took the WD-40 instead of the glow fuel??? If so.. it ludes
the engine good, so it's no problem.. Plus if you wipe it really good it shines
Man....... Prop "hub" balancing......... &^%#! I should have stuck to my finger balancer[:@]
I keep drill/filling one side then the other..... Guess it's good in my case.... I can now remove
the nose weight I added for balance.... But I may have to go to a nose wheel setup soon
Ohhh I still have it
