RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 06-15-2006 | 09:08 PM
  #3543
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
That screw should be the same size as the blade holder screws-1.5mm When you are checking the spindle or main shaft, roll it on a flat surface (you can do it with the gear hanging over the side)> If it's bent you see it bump up and down. Sometimes you can straighten the main if it's not too bad.
