RCU Forums - View Single Post - pull pull 1/5 cub cables
Old 06-15-2006 | 09:57 PM
khodges
Default RE: pull pull 1/5 cub cables
ORIGINAL: Balsacutter
Wow, thanks for the great responses.
I've never seen a good drawing/description of how pull-pull is done. How do you adjust/maintain line tension, some kind of small turnbuckle on the servo end of the lines?
-Balsacutter
Here's how I did the ones on my 1/5 Cub/L-4. There are several brands (DuBro, Sullivan, Ernst, and others) of pull-pull setups available in different sizes, or you can use coated stainless leader line from your local bait and tackle shop. The ball joint connectors and threaded rod is available separately also. The rod has a small hole for the cable to go through.
Note I crossed my wires; it allows max throw and arm movement while maintaining equal tension. You can also use different size arms between the servo and rudder for increased or decreased mechanical advantage and still maintain equal tension.
