RE: U-Can-Do 3d 46?
Well I got my repairs and mods done. It's a good thing I got to them too because there was some wear that needed to be fixed. I had planned to change out the Dubro valve and go with a fuel dot. Also I the cowl was coming apart at the screws so I was going to change that and add a velocity stack to the Saito 82. When I took the cowl off I found that it had been abrading the side of the fuse. It was wearing right through it. I filled it with some epoxy. I also found that the firewall was getting constantly sprayed with oil so the velocity stack should help that. And the fuel dot will make it easier to fill the tank. So hey! I'm excited to get the Do up and inverted again.
