RE: WHICH ENGINE DO I GET?
The O.S .18CVR or the O.S .12CVR both will do good. The .12 has a little less power but depending on the size of the track you may not be able to use all the power that the .18 has to offer. Remember to go fast you have to put the power to the ground and if your spinning your tires your not going as fast as you could be going.
