RCU Forums - View Single Post - Avistar Taildragger
Old 06-16-2006 | 11:53 AM
raideron's Avatar
raideron
Default RE: Avistar Taildragger
TDubya..
The spring and wheel pivot connection should be in the center of your rudder/fuse gap
(tail wire in center) the other end of the spring (with a little tension) goes into the bottom
of the rudder... Maybe that's what you said above, but was not sure.... But as said, they
all work great!!!... Here's a couple of pics on my 4*(1st try) and UCD...
ID:	478452   Click image for larger version
