RCU Forums - View Single Post - MW44 Flameout Problems
Old 06-16-2006 | 04:08 PM
siclick33
Default RE: MW44 Flameout Problems
I had a similar issue.
Here are a couple of things you might want to try.
Raise the idle slightly. This seems to help and doesn't affect the residual thrust.
Make sure you have the TX setup correct to give enough 'headroom' at the bottom end (i.e. idle should be above 10% from memory).
You could also try changing the stability delay figure.
