RCU Forums - View Single Post - can not get it to hover
Old 06-17-2006 | 12:54 PM
Truglodite
Default RE: can not get it to hover
what tippy said. usually the electronics are mounted up front and that shouldn't cause the problem you describe. in fact mounting is usually a non-issue as long as you're balanced, the gyro is oriented correctly (axis || main shaft), and there are no glitches caused by esc/rx induction.
