RCU Forums - View Single Post - Official HPI MT2 Thread
Old 06-18-2006 | 09:43 AM
  #6656
46u's Avatar
46u
Default RE: Official HPI MT2 Thread
ORIGINAL: Daverallye
Hi
I my mt2 was making a noise when accelerating, like teeht were skipping, so i ttook the rear diff apart, and found loads of metal bur, so i bought a new diff gear ( the biggest one that was warn) and put that in, and ran it for the first time today, but its still making the noise ??!??!?!
Any ideas lads ?
Thanks Dave
If ring gear was stripped more then likely the pinion gear needed to be replaced as well. If you have the RTR you should up grade to the heavy-duty gear set and make sure you shim them. All so did you check your spider gears?
This is the heavy-duty gear set.
http://www2.towerhobbies.com/cgi-bin...7&I=LXJYM2&P=K
Good Luck and keep us posted.
