RE: Need Valve Dimensions
Thanks Bill,
These are the times I wish I had a nice small CNC Lathe to knock out a few dozen of these parts. Guess I will go ahead and start to make them using some Stainless Steel Bar Stock I have in the shop. Unfortunately turning the stem to .094" from the .250" bar stock will create some flexing of the piece during turning, especially with Stainless. Heads will be easy, just use a starter drill with a 45 degree angle (90 degree total) and the job is done. Thanks for the reply. Larry
