RCU Forums - View Single Post - Seagull Edge 540 - 68" (60-90) ARF New v2- Building
Old 06-18-2006 | 12:10 PM
Tesla1856's Avatar
Tesla1856
Default RE: Seagull Edge 540 - 68" (60-90) ARF New v2- Building
Thanks for the help ... That's a clean looking mod. you did there.
Ok, so I left it at 130mm and drilled the motor mount. I also ground off a tiny flat edge on that corner's motor mount washer for additional clearance. That puts the black carb. screw 1mm from the motor mount.
I was looking at the Dubro spinner I'm going to use and noticed it has a lip on it that will close the gap by 2mm (of the 5mm I was over) so that leaves just 3mm which shouldn't be a problem to make-up with the cowl spacing or leave as is.
I also moved the throttle cable wire over 3/4" to put it behind the carb. throttle arm.
There's more info. on this build over at my website:
[link=http://www.vlsdynamics.com/rc/planes/seagull_edge_540.htm]My Edge 540[/link]
ID:	479343   Click image for larger version
