Gtarling,
Thanks for your comments, here's another one from Hobby Lobby for the same airplane. This is probably more in line with your ideas.
Thank you for the opportunity to convert your Glow plane to Electric power. Here's everything you'll need to complete your Glow to Electric Conversion of the 1/4 scale DH Tiger Moth. This setup provides over 1700 propeller watts.
Motor, Motor Mount:
PM533018 AXI 5330/18 Electric Outrunner Brushless Motor ..... $ 249.00
Prop:
PE18010E 18x10E Thin Electric Prop ..... $ 11.60
Motor Controller:
JESAP90PW Jeti Advance PLUS 90 WITH Program Card ..... $ 252.00
Batteries, Connectors:
Two- FM32002 Kokam 2 Cell 7.4V, 3200 mAh LiPoly Pack ..... $ 98.00
Two- FM32003 Kokam 3 Cell 11.1V, 3200 mAh LiPoly Pack ..... $ 145.00
(10S1P configuration)
FMAC03S Series Module w/Deans Ultra Connectors ..... $ 15.90
DEA1300 Deans Ultra Plug Connectors, pair ..... $ 3.50
Charger:
AST109 Astro Flight 109 Lithium Charger for up to 9 Cells ..... $
129.90
Notes:
Unfortunately I do not believe that this project can be successfully
done with Nicad or Nimh batteries. Using the highest discharge Nicads
that we have, your battery weight would be 9lbs.
Setting the end points for the throttle to mimic "scale speed" could probably handle the excess power and extend flight time.
