RCU Forums - View Single Post - LT-40 owners - prop and throws after solo'd?
Old 06-19-2006 | 12:17 AM
somegeek's Avatar
somegeek
Default RE: LT-40 owners - prop and throws after solo'd?
Control surface joints sealed.
Control surface servo range throws maxed.
Dual rates set
high for max throws
low for standard throws
Not sure what to set for expo? I know it needs to be negative so the initial stick to servo movement is slower than normal... Any suggestions where to start %-wise?
Appreciate the feedback.
huddlehd2 - I'm running a 12x6 APC on a .46 OS AX fwiw.
somegeek
