RE: Airworld Hawk Building thread
Looking good David.
On another matter, I am getting close to flying mine(in primer) and am setting it up. Part of this is juggling the equipment to get the CG right. According to the info I was sent the CG is 20mm in front the 35mm wing tube. My question is really aimed at Henry/Ali as they have built/flown a Hawk, did you set the CG at this point? If so did you find it OK ie was it twitchy or soggy or about right?
Thanks in advance.
Geoff.
