RCU Forums - View Single Post - DA Engine with a 3W ignition??
Old 06-20-2006 | 07:49 AM
mglavin
My Feedback: (31)
Default RE: DA Engine with a 3W ignition??
ORIGINAL: Ryan Nau
Just wondering if I can use my spare 3W ignition for a 3W 150 with my DA 150??? or do I need one from DA
If you utilize the pick-up as well as the module and its earlier vintage its doable. The DA and 3W pick-up units are wired differently, that said one could rewire the pick-up connector if need be. The inverse is true too, a DA ignition system will work on a 3W. The latest 3W ignitions are not compatible for swap overs as the hubs require a different magnet orientation if memory serves me.
