RCU Forums - View Single Post - Fox Engine Advice Needed
Old 12-27-2002 | 06:23 AM
NM2K
My Feedback: (14)
Default Fox Engine Advice Needed
See if you can swap the .78 to a collector for another ringed .74.
If you do decide to run the .78, adjust the high speed needle to 1.5 turns open. Then adjust the low speed needle until the engine idles perfectly. Only after you have obtained a good idle can you adjust the high speed needle with the butterfly equipped carb. Good luck.
The .74 adjusts like every other modern two needle carb.
