RCU Forums - View Single Post - More Advice...paint types
Old 06-20-2006 | 03:27 PM
TANKDUEL
Default RE: More Advice...paint types
I used that tip Ian,but not on a tank yet, only buildings so far, except I used household glass cleaner, with good results.It has an anti dust ingredient,that can't be a bad thing
Neville
ORIGINAL: Plastic scouser
Here is a tip i picked up for thinning Tamiya acrlics and i have had no problems so far, its to use windshield washer fluid for thinning acrylic paints. Now, every time I airbrush, I get great results. The WW fluid (I use the cheap stuff from a gallon jug, sold at discount stores all over) has some detergent in it, which helps to break the surface tension of the water-based paint, allowing it to flow more freely. I use the blue tinted stuff, but the color has no impact on the color of the paint- even when painting with white or light yellow.
Hope this helps
Ian
That does help. Thanks, Ill give it a shot.
[/quote
