RCU Forums - View Single Post - Engine Cleaning
Old 06-20-2006 | 11:49 PM
srm99
Default RE: Engine Cleaning
carbon is what a by product of burning fuel now there can be a excessive buildup as running it rich too long but when u take your piston out you loose where your rings were seated so then u need new rings and need to hone the bore to get a smooth linning for the new rings to reseat .
the trick is tune your engine perfect and get a oil like castrol active 2t or one with a little cleaning agent in it and not run it rich and carbon should wear away .
what is wrong with your engine [X(][X(][X(][X(][X(][X(]
