RCU Forums - View Single Post - Pletti Extra 30-10 evo
Old 06-21-2006 | 01:05 AM
can773's Avatar
can773
Default RE: Pletti Extra 30-10 evo
Benoit
Yes I think that 85A is quite high and probably not the best for the batteries. The 21x14 was the only prop I had with me today, I will try the 21x13W, 21x12W as well tomorrow (or the next decent day). Both props should shave about 5A off the setup. As you can see the draw is very dependant on pack temperature! If the packs are warm though the power is unreal.
Consumption for P-07 of the flights I did today was identical to the previous motor...however if you get carried away on the throttle it could be much higher! The 30-10 was good for 95% of the flight, and Evo actually draws less at similar rpm's....so its possible to use less...however I think that is offset by the few times that you want extra power and bring the power into the 70A+ range in flight for a few seconds.
