I called Fai at Airborne Models when I ran into the same problem building mine. The trick with the Groovy 90 is to use the built-in down-thrust angle of 2 degrees as your reference for setting the stab: Block up the fuse so it doesn't move on the bench and put your incidence meter on the thrust washer (motor is installed). Now, you can either set it to "0" or "-2" degrees, whatever you like. If you set it to -2 (that's what I did) when you move to the tail, set your incidence to 0. Next, set your wings at +.5 for starters. This will get you in the ballpark. If you start with a reading of "0" on the thrust washer, make sure you think it through as you set everything. You'll need to use +2 for the stab. and +2.5 for the wings. Make sure the meter is facing the same direction for all of these operations or your readings will be wrong (ask me how I know this).
Mine was tail heavy with an OS 91Fx. I guess a carbon stab. tube would help. One other thing - the rod that is used to hold the stab incidence was a loose fit in the little brass tube on my model. I think it's 3mm (can't remember). I used a piece of 1/8" music wire instead - nice tight fit.
This plane is good for Sportsman and even Intermediate, but try to keep the weight down. Mine came in at about 9 lbs. With a 91 (w/o pipe) it's marginal for Intermediate.
John Pavlick
http://www.idseng.com
