Is it ok to run savage 21 on sand?
I live in Central FL, and all we have here is sand. My T-Maxx is over 4 yrs old, and if you clean it after you run it, use a good filter and oil (I use Bel-Ray) and don't use any kind of lubricants that will attract the sand (outside of tranny and gearboxes that is), it shouldn't be a problem. A skid to cover the bottom isn't a bad idea either, anythng to help keep the sand out. I also knock the loose sand off between runs. Hope this helps.
