RCU Forums - View Single Post - HARMON ROCKET
Old 06-21-2006 | 09:38 PM
  #55
bingo field's Avatar
bingo field
Default RE: HARMON ROCKET
I used this Hangar 9 gear set. Check the inside / most center screws on your gear frequently, I finally used a dab of RTV on the underside of the head of the screws to keep the screw from backing out. Try to remember to keep the axles as close to the LE as you can, too far forward will make it want to ground loop....
ID:	480976   Click image for larger version
ID:	480977   Click image for larger version
