RE: half-tank lean problem!!!
The way to cure it is put a smaller different tank in it. I do not want to cut down on my run time and since it is not a big problem with mime I am not changing any time soon if at all. The tank is bigger at the top then at the bottom and when it gets to half full it makes the engine lean out. Some say then have a big difference and some like I does not seam to make that much of a difference but I can tell it.
