RE: Cowl Screws - Nothing to screw into?
That is a good way to mount a cowl to the firewall. I like the nylon bolt idea. I had not thought of that. The nylon washers I tried with steel bolts and they did not work, it still wallowed out the holes. Sounds like with nylon bolts the problem is solved.
