Hey thanks Blisster!!.... And a *BIG* Congrads to Logan!!!.. I tried to get my grandson
and granddaugther to fly... And since it was free I even got them into the AMA.. I corded
with them on my Avistar.. he was doing good, but he was 14 at the time, and his
interest has changed somewhat...Rachel went out about three times and was a bit shaky,
on the last outting, she say's Gramps, this seems like a lot of fun and it's really cool
watching you fly.... But I don't think it's for me and you get up Waaay too early to get out
here...
I'm not so sure it's coming from the battery???? Only because I had the rec/wires in
different position, wire tied together/untied, hanging loose/tucked under the battery etc.
and I got the same results with three different rec.'s, 2 batteries, 2 HS 645MG servos'
and I also switched out the ext. on the servo even tho the connectors/wires looked brand
new.. Ohh tried another charge switch too.. plus all the medal removal from the tailwires.. [:@]
I think this one is "Busted"... As in, I give up [:@]... So, it's either going to tell me, "Hey
here ya go.. I'm the problem" Or I break down and buy the Glitch buster...
Had a Great Day with the "Do" on Wed. It made less noise also, Guess the ^*&#% Prop
balancer is working... But it could have been the weather stripping I added to the wing/fuse
joint....... I have been practicing with blenders..... Man, They do look violent to the plane
just before she goes into the slow flat spin... Hey maybe it'll knock out my glitch
On one of them, I blipped the throttle a bit more to gain more rotation just before I inputted
the rudder... WoW.. I thought the "Do" was going to come apart....
