Originally posted by DMcQuinn
I am using 8 JR ds 8411 servos on my 35% Cap. Have over 100 flights in a two year time frame. My only gripe is that they oscillate the surfaces quickly when there is no load on the surfaces.
I have the same issue with oscillation. Unfortunately, the oscillation also causes premature wear when then leads to slop in the gear train. Its a never ending cycle.
I have been replacing the gears in my 8411's every 50 to 100 flights to solve the problem. I've since switched to using other servos (Airtronics 94358's, 94258's, Multiplex, etc). Just to expensive to run the 8411's.
