RE: Control horn problems on 73" Yak.
Ok, I'm going to modify the horns so that the hole is in the same place on both horns. I'll make sure it's a good 1/8" away from the other holes. If it comes up a little short then I'll move the subtrim the other way, at least it will be a bit closer and both sides will be the same.
schu
