RE: Bad Pushing Problem(w/ hyper PCR)
Yah hes right i forgot about the servo arm if you loom when you tunr the stock servo arm flexes alot. Im using a sirtronics servo so im using tyhere heavyduty servo horns, and it doesnt flex at all. its reinforced with aluminumn, and is very strong plastic. Hre are the ones im using, [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXTT14&P=0]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXTT14&P=0[/link]
Also as long as your track isnt really bumpy you want to get a sway bar in the front, i know it doesnt come wityh one. Maybe im confused abotu sway bars, but LSUfreak said that you should take it off, im preatty usre thats wrong, a swaybar helps the car turn better, you just dont want to use it if your runnign on a very bumpy track. All i know is after putting a sway bar on my car (I modded the rear one to fit the front) ands now my car turn better.
Oh i just noitced that you have the 94358 (so do I) and this servo comes with this arm, and if your using the one that comes with tyhe car make sure you switch it out for this one, you just need to drill the hole bigger where the linkage hooks up.
