RCU Forums - View Single Post - GP Tracer for first build
Old 01-30-2002 | 06:05 PM
Scorpionjack's Avatar
Scorpionjack
Default Tracer
Zee;
The tracer is a very nice intermediate level aircraft. Fly's pretty much where you point it. Tracks very nice on uplines as well as inverted with minimal down elevator. Building is straight forward, one change would be the Landing gear blocks. When installing your Wire gears you'll have to really angle the hold downs as there fairly narrow(Less than 3/4 "width). Recommendation would be to sheet voer the whole landing gear block. Then cut/open the slot to install the gear then use care and cut the slots to fit your landing gear hold down straps. This will give a cleaner appearance as well more strength. Second minor modification is I built a enclosed tailwheel molded into the rudder. The plane flew at about half throttle with a YS 63, grass take-offs were not a problem. Hope this helps.
AMA 6518
