RE: RC Smart 30A Brushless Speed Controller
VULTCH,
How bout this one? I just received 6 of the new version TP 30 esc's.
Came with the same directions you posted.
Instead of the initial 3 of each option, they all only do it 2 times.
And no matter which of the options you try and select, they all do the same thing. Move the stick to half throttle and all you get is one long tone, followed by 3 short, then 5 short, then silence. If you move the stick back up to full the motor cranks up.
I've tried changing throttle trims, reversing the channel, different rx's, 2 and 3 cell lipo packs.
All of them do the same. And if you just try and use them they don't start to turn over the motor till almost 1/2 throttle.
I dug out one of the older versions I have of the esc, and it programs up just like the directions.
Got me totally confused.
