RE: Mixing for 3D?
You can make the mix so that it is only active after reaching a percentage of throw. For example: in knife edge flight ...you usually have to hold at least 50% or more rudder. You can make the mix (say 5% up elevator) so that it only occurs when the rudder is past 50%.
