RCU Forums - View Single Post - 46AX Optimal Prop
Old 06-23-2006 | 01:12 PM
Bax
Default RE: 46AX Optimal Prop
If your engine is running rich of peak RPM, it's just fine. It's normal for it to get hot enough to cause severe burns. As long as it's set to be rich of peak, and is running well, don't worry about its temperature. We never check temps on engines we run.
