RCU Forums - View Single Post - Boring carb spacer
Old 06-23-2006 | 07:18 PM
av8tor1977's Avatar
av8tor1977
Default RE: Boring carb spacer
EERRiiicchhhh.. (Brake sound)
You really don't want to try to drill out the carb spacer. There is a VERY good chance the drill will catch, and destroy the spacer. I just use a sanding drum in a Dremel tool to ream mine out... only takes a few minutes, as the material isn't very hard. You want the spacer to have the same size hole as the outlet of the carb. Also, if that makes for a step where the spacer fits to the intake port, you need to blend the step out as it will be an obstruction to flow.
Good luck,
AV8TOR
