OS 91FX for pattern use
Jeff, Do you have any RPM measurements for the OS91 on that APC 14x10? Just want to know how it compares against my old Super Tigre 90 before it bit the dust. I was using a pipe so that's probably worth 3-400 revs. On a good day it would turn a 14x10 at 9,400-9,500RPM on 10% fuel. Trouble was, not all days were good!!
Mike, I would try to get hold of an OS Hanno pump and check if it fits (no better pump ever made IMHO). Failing that, try a Cline regulator. The pipe from the Cline to the carb needs to be short (3/4") to work well but with the OS being a rear mounted needle, that shouldn't be difficult. Allow enough room behind the engine for the regulator & plumbing and don't hard mount the reg. as it doesn't like vibration.
Alan.
