RCU Forums - View Single Post - sig kouger aileron install question
Old 06-23-2006 | 10:58 PM
cloudancer03
My Feedback: (22)
Default sig kouger aileron install question
I must be nuts but I never built my kougar and decided its time to get it done.my question is can I build independent wing servos rather than use the old fashion horns that typically came with the older kits??
Can I even use tail mounted servos one for rudder and the other for elevator..I dont want in the worst case scenario to use balsa sticks as pushrods..I built many a plane that way when I was younger but technquies change and there has to be a better way.if forced to I will use arroe rods or a composite rod.
sure would appreciate everyones advice.I see the plans called for a thirdline back then due to closed cowl.that will be easy and I'll just use a fueldot.man this should be a great plane when done.yeah I know there are arf's and I have them too, but building is part of the fun too and I just feel the need toget this one out there..
