RE: ESC
it is perfectly o.k. to run 2 motors off of 1 esc providing it has the capacity to do so,the motors must be wired in parallel not series,you can use 2 esc's but there is no need,if 2 are used the bec must be disabled on one or you'll blow your rx.
