RE: Showtime
Banche... I had the same problem on the tailwheel springs... I started to move the
attachment point to the front, but then I just "stretched" both springs as Barry said,
there a bit loose in the neutral position, but no ground handling problems. I used all
the stock equipment, except for a tetra fuel tk.<sp> tk. for the YS..
No flt. or equipment problems in about 65 flights.. I did Gorilla glue my stab/wing
tube in... She flys Sweet... Added another 3 flts this morning I'm getting "lower" &
slow.. But not sure how far down I'll go[:-]... It was just to HOT around 8.. So had
to call it a day............ The Heat is on, in this here AZ...........
