Sevro programming and PE problems
Hi, I am running all Hitec 5735 digital servos. They are programmable. I set the servos for certain end points with the hitec programmer and set everything else the way I want it. Then I plug the servo into a channel on the power expander which is then hooked up with my reciever and regulator and then my double 2400 LI- Ion batts. My problem is after i set the settings for end points with servo programmer the servos work fine. I plug them into the expander and they only move a tiny ammount against what i set them to with the programmer. Can any one help please!
Jon
