New Memebr needs help: I keep crashing
While I agree that you should contact a club, I also am looking at the web page for the "zoom pilot" which is the closest thing at hobbico's website.
What does those 20 feet look like? Are they smooth, then a drop? Is the plane climbing steeply, then dropping?
If it is the first, I would try is a little up elevator. Since they only provide two channels (throttle and rudder) you are limited to setting the elevator before takeoff.
If it is the second, I would center the elevator and then slightly rise it. You should barely see a change between the stabilizer and the elevator.
In fact, you want it to glide slightly downward when you don't have power, and climb when you do.
