RE: Super Tigre G3250 issue
Some things to consider: How old is your engine? Italian or Chinese production? Does it have the insert inside the carburetor to reduce the opening? What muffler are you using? What size fuel line are you using (inside and outside of the tank)? Did you start out with very rich low-end and top-end settings and set the high-speed first and then work on the low-speed?
The answers to these can affect how your engine runs.
