Still putting mine together. Seems like this is quite a sturdy plane after all
A question to you Larry, do you use the wheels that you got in the kit and do you fly off grass? If yes, then is the plane able to lift the rear and show that it has sufficient airspeed or do you have to parry with the elevator to prevent a nose-over?
