RE: Should a motor point a little to the right?
If the plane showed slight right and/or down thrust assembled as per instructions, more than likely it was intended. This is a common design feature, though not universal. Some planes actually have left or up thrust designed in, however this usually depends on the overall configuration of the airplane, ie tractor/pusher, a pylon mounted motor, etc.
