2 speed problems
My 2 speed is not shifting into 2nd gear. I took it all apart and pulled the trans and installed the FOC while I was at it. Everything looked good in the 2 speed, so I cleaned everything and put it back together. Still no shift. I have adjusted it, but cannot get it to shift. Any suggestions?
BTW: What do you guys use for trans lube? Can you use diff lube, or just use grease? What about switching the FOC gears around for more top end????
