RE: Oxai E-Pinnacle Build
I'm sure in a snap they are pulling something like 4A total, but a 480mAH pack can put out 10A briefly. It covers your burst and capacity needs safely - just needs to be recharged more often than a 910mAh.
Definitely put some flights on your plane with the 910 pack, then use a charger with capacity display to verify that your system is using similar capacity per flight.
