RCU Forums - View Single Post - Need engine advice
Old 06-27-2006 | 11:02 AM
3dsky's Avatar
3dsky
My Feedback: (84)
Default RE: Need engine advice
What prop and what was your RPM. You should be in the range 6400 to 7100. The Fuji 50 should have been enough power to loop at just over ½ throttle. What is your total weight? Is the engine under any warranty? If yes, send it in for service. Hope you get it working, the Eagle is a great flying plane. If this is your first gasser than I would try to solve the problems with the Fuji, you may have other issues that are messing the engine up. Heat build-up is just one. If you change engines you may have the same problem. I would find a guy in you area to check it out. The Fuji is a good engine for your first gasser.
