RCU Forums - View Single Post - Lite Machines Corona ESC problem
Old 06-27-2006 | 12:33 PM
jkf6634
Default Lite Machines Corona ESC problem
I have just built a Lite Machines electric helicopter. I have a 7 cell Sub C, 3000 mAh battery pack, brushed Kyosho Atomic Force 17 turn motor, and a GWS ICS600H ESC. The ESC has a BEC and I am running 3 micro servos. My problem: The motor starts and runs fine at any speed, but when I start moving the servos around the motor shuts down. I can get it to shut down almost every time by working the servos. Sometimes it takes longer than others. The servos continue to work after the motor shuts down. There isn't a low voltage cut-off on the ESC so it shouldn't be shutting down for voltage reasons. Any thoughts or suggestions? Thanks for the input!!
