RCU Forums - View Single Post - Skymaster
Thread: Skymaster
Old 06-27-2006 | 08:57 PM
Ali's Avatar
Ali
Default RE: Skymaster
I agree with Shok. The ones with Flaps and ailerons I flew did not fly any better than the elevon version. If anything worse as they were carrying some extra weight. The trick with the YF-22 as with most jets of this type F-15/ F-18 the best approach is to keep the nose up and use this as aerodynamic braking. You can then balance this angle of attack with some extra power. It sounds strange that you are landing with a higher throttle setting but if done right slower.
Practice up high. Spend a flight slowing the model down and as you increase the angel of attack add extra power and then some more angle of attack, then some more power. Do this reasonably high as you can get it stalled and this can take quite a bit of height to get out off. Dont panic, open the throttle to full let the nose drop a little and it build up speed and then you can fly off.
I have seen people practice this and get to a stage where they have full throttle on and such a high angle of attack that they do not climb, just crawl along on the edge of the stall. Dont try to land this extreme but closer to it than with a flat type nose down approach.
Hope this is of some help.
regards Al
